Adam's annoying ass green 620
Eagle_Adam
#461
Post by Eagle_Adam »
ah, your is about as bad as mine...
no worries man ill pass, but thank you!
plans for the weekend are to re-install my tank, rear-end, disc brakes, and 4x4 leafs
Eagle_Adam
#462
Mmmmmm powder coat
#463
Whosoever phone that is, it has terrible white balance. That Green just is not popping enough in that pic.
Eagle_Adam
#464
The green just doesn't photograph well
Eagle_Adam
#465
All of the following happened in this
For the record I hate being cold...
Jessi cleaned up parts while I installed :)
New EFI rated fuel line
Ended up finding 2 cracked rubber fuel lines so dropping the tank wasn't all for not
Filler neck and associated lines are in with new mounting hardware
Gotta drill out two more snapped mounting bolts for the tank then It can go back in
Also got the front leaf spring bushings mod done
Once the tank is in the leafs are next
And I picked up some brake in oil for the KA
#466
I wanna come play! But alas, I am banished from Datsuns til I finish the work on the house! Actually I am going a little crazy with all the house work, and a bit tired. Soon.
#467
You're a bunch of badasses. Too cold for my tired old bones. Me and my fat dog haven't ventured out of the house for more than 2 minutes at a time in 3 days. There's no heat in my shop so it's basically just a shelter from the wind. I worked out there Thursday night for a couple hours and had enough. You guys look like you're making great progress.
Estimated fire-up date?
#468
The only work I did on my truck was some donuts in parking lot with 2" worth of ice in it :troll:
Eagle_Adam
#469
Laecaon wrote:I wanna come play! But alas, I am banished from Datsuns til I finish the work on the house! Actually I am going a little crazy with all the house work, and a bit tired. Soon.
Ur always welcome, but it looks like ur balls deep in house work....
Eagle_Adam
#470
DRIVEN wrote:You're a bunch of badasses. Too cold for my tired old bones. Me and my fat dog haven't ventured out of the house for more than 2 minutes at a time in 3 days. There's no heat in my shop so it's basically just a shelter from the wind. I worked out there Thursday night for a couple hours and had enough. You guys look like you're making great progress.
Thanx! If I don't get my ass out there it will never get done and this is supposed to be my DD...
We did pick up a new space heater for the garage today, it was almost 10 degrees warmer, a balmy 40 :D
Eagle_Adam
#471
izzo wrote:The only work I did on my truck was some donuts in parking lot with 2" worth of ice in it :troll:
All I got was a dusting....
Eagle_Adam
#472
DRIVEN wrote: Estimated fire-up date?
After Christmas, family time is important to me so it is what it is for now
Eagle_Adam
#473
Well I've got the gas tank and lines back in now and bolth leaf springs are in as well but I need to go get hardware to bolt the leafs together.
#474
The bolt to hold it all together? If so, thats a fun one! I had to fix a friends once since his snapped. Used a regular bolt, rounded the head to fit in the axle hole, and assembled. At work I have just drilled the hole bigger for aftermarket springs. Its also really not fun to get the leafs to align to tighten it.
Eagle_Adam
#475
Ya aligning the holes was a pain...
And I ended up enlarging the opening on the axle just a bit to accept the bolts I'm gunna end up using
But I have no nuts that fit..... And I'm out of crush washers so it's off to ace tomorrow
Eagle_Adam
#476
and just to toss it out there cus i never could get good pics under the truck but heres what my gas tank looks like.......
and i re-installed that POS............. drives me insane
#477
That must be the low pro version?
Eagle_Adam
#478
You would think but my truck wasn't lowered until I got it... And It was that way when I got it
uberkevin
#479
Post by uberkevin »
What's next on the to do list Adam?
Eagle_Adam
#480
Install the axel housing, rear axel shafts, rear disc brakes, then address the cross member flip before this weekend
