The Blue gO_0n Build?
Draynor
Cars: 71 510 wagon
Re: The Blue gO_0n Build?
#141
Post by Draynor »
So I thought id show what I am doing with the rest of my time, when not working on the wagon. Going to PCC for welding.
Just got done with the final exam today, Got a A :D
#142
Erm, machine shop yet?
Draynor
Cars: 71 510 wagon
#143
Post by Draynor »
No, I need to stop by and grab that other crank from you, too see which one he thinks will be best to use...
Might go tomorrow though, Just to get the pistons over with.
#144
Ah, yes. Well once you get everything squared away, its on like donkey kong!
#145
Beautiful welds Draynor :thumbs:
Congrats on the A
#146
X2 dude^^^^^
:fry: :yuno: post longer video?
Eagle_Adam
#147
Post by Eagle_Adam »
draynor stopped by last night to borrow a coupla tools......
and i cant leave well enough alone so we ended up:
deleting some un-used wiring in the bay
pulling his rad to flush it trying to figure out why he had virtually no heat
tossed in a new thermostat
and tightened some nuts n bolts
but i digress...
i looked up into the rafters of my garage and noticed the 280z center console i had up there that i forgot about......
fits pretty good IMO
#148
What kind of welding was that? Kinda looked like stick.
Draynor
Cars: 71 510 wagon
#149
Post by Draynor »
Yea it was stick. Got to get threw this so can can start on wire feed :D
#150
I've always sucked at stick welding. Yours came out beautiful.
Did you guys try to flush the heater core itself?
#151
Removing the heater core from the car is easy. I refoamed mine while it was out. Also let it sit for a few hours with CLR in it.
I also hooked my hose up to it, first forwards flow, then reverse flow, then forward flow, all until it was clear. I just hose clamped onto the firewall ports.
Draynor
Cars: 71 510 wagon
#152
Post by Draynor »
Didn't flush the heater core or take it out. Didn't really want to do all that at Adams place and take up a bunch of time. We were out there till midnight as it is...
#153
I did stick welding too. Mine came out just like that. Stack of dimes laid out ftw!
Get on that wire feed. i stopped schooling right when I was supposed to start wire feed. Did oxy and stick, though. Wire feed and tig was what I wanted to learn the most :|
Draynor
Cars: 71 510 wagon
#154
Post by Draynor »
New pistons are now pressed onto the rods, also got the polished crank back. Ended up using a different one I had due to some scouring on one of the journals.
Almost time for some LZ :thumbs:
and some car pics...
kylezone
#155
Post by kylezone »
I was thinking about taking a class at PCC this spring, now im thinkin about welding too. looks great!
Eagle_Adam
#156
:thumbs:
Draynor
Cars: 71 510 wagon
#157
Post by Draynor »
Honed the block last night, got to the bearings and I forgot the assembly lube. Hopefully tomorrow some work will happen.
Just picked up a gasket set. Almost have everything ready to go... :D
Draynor
Cars: 71 510 wagon
#158
Post by Draynor »
Got the short block together tonight :D. Jacobs gonna try and paint the block tomorrow, and i'll be going back Tuesday to finish the rest...
Cleaned the head up and the KA oil pump
#159
We used the same assembly lube as I did on my L19, 50/50 of STP oil treatment and engine oil.
Plastigauged the bearings and all came back in spec, right in the middle.
Rings were checked for gap, and all came back in spec. (My L19 had like 3 rings a little tight). Rings went on. and then compressed. I managed to get all 4 pistons in first try. I was all "I dont know how this is going to work..." and its in.
Pistons look good in the block.
And some higher resolution photos.
Everything is tor
Converted_to_datsun
#160
Post by Converted_to_datsun »
So I wish the thumbs up thing was bigger... My fat thumbs gave it a thumbs down instead. Why no way to fix??!!
